Tilt and trim switch on 50 hp Jonny.
heycods
The up possition part of the trim switch is out or it has a broke wire in the stick on my 96 mod 50 hp jonny. it has the original omc stick that mounts to the side of the boat as it is a right hand console Sea Ark boat.
I find no screws to seperate the stick to get to the switch, I un glued the omc plate at the bottom of the stick no screws. This is the gear shift- throttle with the TR&T switch operation under your thumb. I have manual on motor but it dosent cover the controll mechanizem. ? /? ? ?
The motor has a t&t switch as is thier a bow T&T switch, up possition works fine on them so it has to be in the stick wireing or switch.
HoW DO I GET THE SWITCH OUT?
mikesea
Re: Tilt and trim switch on 50 hp Jonny.
need to remove the control box,which will give access to the screw that holds handle to box,back side of handle has screws for the switch cover
