tilt and trim wiring
gap705
We are rewiring our OMC cobra and trying to fix a very sloppy job done when an "86 tilt/trim was put in a "90. We have added the second selinoid which was left off but now we are unsure which of the three wires coming from the tilt/trim is the ground.... blue/black/green??? Wiring diagram in OMC book shows blue and some helpful people here have told me blue up, green down and black ground. The orginal set up had a connector which is no longer there so wiring diagram doesn't help but shows orginally as the trim/tilt motor three wires go into connector and then out of connector to grn/wht to down solenoid............blu/wht to up solenoid and I am guessing blk to ground. How do I wire without connector? I am learning a lot about wiring today.......thanks for all your help.
Trent
Re: tilt and trim wiring
Cut the connector off and straight wire with butt splices.
gap705
Thanks to all who helped. We have that trim and tilt working really great........fast up and down. Amazing how much difference spending a little time doing it right does!! Plus a lot cheaper!!
achris
More fish than mountain goat
Not to mention reliable and easier to repair if it fails in the future.
