Tilt gauge wire'n
Todd T
I am redoing an 87 bayliner 2450, new gauges and a tilt gauge, followed the wires from the sensor to a connector that the wires run into the harness,
tried checking for contunity with a long jumper wire from the connector to under the dash and am not finding the wires to the sensor at all, before I just rewire it
I thought I ask if any one knows and what the color code might be. Thanks
sam60
Re: Tilt gauge wire'n
Give us some more info on your boat and put it in your signature. What engine is it? I might have the wiring diagram.
Todd T
The boatt is a 87 Baylinner 2450 Sunbridge.
It has a 5.7 Chevy engine thats 2 years old as I was told from the seller, It had the 5.0 chevy engine previously
the outdrive is a OMC cobra. The sensor is there....but it didn't have a tilt gauge.
Thanks for your help.
bruceb58
Bayliners didn't put the gauge on the boats in that year. I had the same year. It is highly unlikely that your sensor is even going to work anymore either. Very prone to failure and not worth replacing in my opinion.
