Tilt Lock Parts Search 1974 chrysler 120 hp #2
wickware
Hello Nordin & Others, Do you have a parts diagram link to, ?Tilt Lock Parts Search 1974 chrysler 120 hp?. Posted today. Can the frozen Tilt/Lock Pin/Rod be driven or drilled out w/o any danger to Al Casting/Housing?
jerryjerry05
Re: Tilt Lock Parts Search 1974 chrysler 120 hp #2
http://www. boats . net/images /diagrams/Merc/CHRYSLER/FOB3081/16.png
Look up any late 70's or mid 80's 55 hp and the tilt lock is pretty much the same.
Here's a pic of the parts.Not quite the same but will work.
The parts should be able to be changed with just hand tools and a pin punch.
Easy job if the motors off, a bit tougher if on the boat.
Someone suggested WD or any spray lube PB Blaster works great too.
