-- 1996 130hp Evinrude - PTT not wanting to tilt up on occasion.-- It always tilts down without any issues, but not up.-- The hydraulic fluid is full. -- I made sure the battery was fully charged and tested both the trim switches. -- I’m thinking this is a relay issue. -- I tried removing one relay at a time and then trying both up and down, -- I also swapped the relays and still just tilting down worked. -- Does this issue sound like a bad relay? -- If so, does this motor require both to be plugged in for up and down to work?
Both relays need to be installed for the PTT junction box unit to function.
Switching the relays and the problem remaining the same proves that both relays are okay. Both relays are supplying voltage in the down mode.
Very unlikely that both PTT switch would fail at the same time in the identical manner. Suspect they're okay.
NOTE: The PTT electrical motor is a dual polarity motor, meaning that connecting the battery wires via small jumpers to both of the motor wires will cause the motor to run in one direction... and reversing the wires will make it run in the opposite direction.
Test the electric PTT motor as follows:
Trace the wiring of the PTT electric motor from the motor back to its connector and disconnect it.
Run small jumper wires directly from the battery to the two wires leading to the electric PTT motor...that should make it run in one direction. Now, reverse the wires... the motor should run in the opposite direction.
If the electric motor runs as above, it is okay... If not, the electric motor needs repairing or replacing.
If the electric motor runs okay via the battery jumper wires, but not with either of the PTT switches, the problem would most likely be that voltage is not being supplied to the PTT switches via the Red voltage supply wire... check it! If this is the case, it'll be up to you where the break/flaw is with the voltage supply.
Let us know what you find.
