Tilt problem
knuuttila
I have a johnson 120 and for some reason the tilt will only put the motor about halfway up(so the prop remains in the water).<br /><br />It goes up and down fine, but not all the way up any more.<br /><br />What do I need to check. I can,t see anything wrong with it anywhere.<br /><br />Rgs<br /><br />Brian
DHPMARINE
Re: Tilt problem
Check your manual,sounds like you are low on tilt fluid.<br /><br />DHP
