tilt/trim Click
andycap10
The tilt/trim on my 1991 mercruiser alpha one will not operate. When i press the Tilt/trim buttons it makes a clicking sound. The clicking sound is comming from the tilt/trim pump. I cleaned the connections on the Solenoid located on the starter. I have no idea if there is another solenoid i should be cleaning or what. The problem happened all of the sudden, just after getting back from cruisin'
Re: tilt/trim Click
There's a Solenoid or two mounted On your trim pump......<br />Try those........
