Tilt Trim Hydraulic Fluid, Which Fluid?
dfwyatt
To run the hydraulic til trim rams, what type of fluid do you use? And whats the best? I have a 4.3L + Aplha One.<br /><br />I have hear dmotor oil, atf, and others? What should I use?
Don S
Re: Tilt Trim Hydraulic Fluid, Which Fluid?
Mercruiser recommends 10W30 motor oil.<br />Check in your owners manual or service manual, it's in both.<br /><br />This is from the owners manual.<br /><br />
beezee28
Master Chief Petty Officer
I have a 3.0L mercruiser 1997 and the manual said to use a 30 weight oil. The change the oil last season and replace it with the 30 weight oil.
BoatinBen
I have an OMC Cobra 3.0 but the tilt/trim motor looks as if it has ATF in it(red as cherry koolaid). Should I drain and change it? If so, what does it call for and how how to completly drain it?
Don S
OMC and Mercruiser are different.<br />It depends on what pump you have. They used different pumps for different years.
