Tilt/Trim indicator
Gmanpumps
2001 Mercruiser 5L, alpha outdrive, carburated. Tilt/trim indicator on dash is permanently stuck in the far right position even though the outrive pivots fine. Gauge has 12v to it but I am uncertain if this means the gauge is bad or something else, ie sending unit. Any ideas??
Coolmaker
Re: Tilt/Trim indicator
Check the sending unit on the outdrive. Also if it is stuck far right, probably the wire/sender is shorted. And you might get better results in the Mercruiser forum...
Gmanpumps
Thanks coolmaker, read somewhere that might be a potential problem. Will check it out. By the way I am from your hometown too. Thanks again
