I have a general question for you all. The manual for for my 91 evinrude 150gleis contradicts itself as far as what lube to use in the trim reservoir . on pages 9-16 and 9-34 under routine inspections it says OMC power trim/tilt and power steering fluid or GM dextronII. However, on page 1-11 it says to use hi-vis gearcase lube in the power trim/tilt res...
Which is correct? The fluid in the res. is "brownish" in color now and I really don't want to mix if I can avoid it. By just shaking the bottles of fluids, the pt/t fluid is obviously thinner than "gearlube". Does anyone have any suggestions? or possibly the color of OMC pt/t fluid.
Any help is greatly appreciated
Ron
Ron
