Tilt/trim; motor up or down
erosenwinkel
Quick question, bought a new set of o-rings for for 85 125hp Force tilt trim. When I refill the motor with fluid, do I have the motor up on the cradle or hanging down like its in the water? Its been a while since I've done this and I have forgotten. Thanks!
Eric
Frank Acampora
Re: Tilt/trim; motor up or down
When you first start filling the reservoir and trying to cycle to tilt, you will run out of fluid 3 or 4 times so it really doesn't matter. HOWEVER: When you get near full with all air expelled from the cylinders, SOME systems do develop pressure in one position--I forget, it may be down--At any rate, it will say so on the motor.
So, top off the fluid in whatever position the motor says
erosenwinkel
My trim motor has absolutely zero lettering/engraving/stamped areas/stickers. Nothing. It is simply white. I did however change all the o-rings in the "home plate" looking thingy. Then I put the motor down as if it were in the water, it made more sense to have all the cylinders closed (not extended). I leveled the boat off so the trim unit was as level as I could get it without digging my hitch wheel into the floor of my garage. Then I intermittently added fluid, raised and lowered, topped it off, raised and lowered again. Over and over about 12 times until it all worked smoothly and free from any air. I assume this is correct. Please advise if what I did was inappropriate.
Eric
jerryjerry05
You fill the resivoir while it's down.
Fill and cycle,fill and cycle.
Filling it while it's up. It can push fluid up into the electric motor.
