Re: tilt/trim not holding
You say I/O. This is an OB forum. But anyway, any leg that tries (does, they all try) to come out in reverse means your T/T cylinders are leaking or you have air in the hydraulic system. After leg tries to come out, shift to neutral and see if there's an oil slick off the stern. If not, check the oil reservoir. It may be pumping air and the reverse thrust is simply compressing that air, allowing leg to rise partially. I assume leg doesn't just jump out of the water.
