dallaspaco
- Sep 4, 2009
- 8
I bought a boat with a 1988 force 125 motor on it.The trim/ tilt does not work.When I bought it there was a plug on the side of the hydraulic motor missing{not the fill plug,but beneath it and to the right of it} so I plugged it.I am trying to purge the air out like the manual says with no success.I can move the motor up and down with little or no resistance from the cylinders or the fluid in the lines,with all the plugs in.There are no leaks that I am detecting.I remove the fill plug,raise and lower the motor 3-5 times to remove air from system,and while the motor is raised,I fill the reservoir and install the drain plug.I have tried this at least 5 times and I can still raise and lower the motor with no resistance,so I assume it is air in the system still.Any help would be appreciated....thank you
