Hi guys,
I am not onto replacing the tilt and trim on my Mercury.
The piston arm ended up snapping. I needed help or advice on how to remove the pin at the top to take off the broken part of the piston.
This is a 2007 Mercury 25hp EFI 4stroke serial #: 0R181035
When looking at the Mercury website and diagram these does not seem to be a lock pin or anything holding the pin in other than the bushings on either side. I have soaked in WD40 (I did not have PB blaster) After letting sit I have tried to hammer it out with a punch and a sledge. I guess my next step is heat? anyone have any ideas. am I missing anything?
On the right side of the motor it seems the pin has a head on it and the other nothing so that seems the way it should be banged out
Help me out here I need to get this out.
