tilt/trim problem
jlj26
2012 outboard merc 4 stroke 90 hp. tilt/trim does not go up. Down works fine. Replaced selenoids. I bypassed the selenoid on the up and it did work. I have changed the up selenoid and even exchanged it with the working down selenoid, but I can't get the up to work. Any ideas?
alldodge
bypassed the solenoid on the up and it did work.
This tells me the trim limit is not adjusted correctly or not working. The Blue/White wire connects to the Red/White wire for UP. For it not working, I would say you may need another trim switch, or the connections to the switch are not making connection Mercury trim wiring OB.jpg
