77Chrysler85hp
- Apr 18, 2010
- 5
I have a 77 Chrysler 85hp motor that I recently purchased. The previous owner said that I needed to add SAE 30 engine oil in it (also Clymer manual ). I read on this forum that I could use transmission fluid which I have on hand and used that instead. I removed all of the lines and flushed out the old oil (which had water in it). After re-installing the lines and adding fluid, I tested the pump and all I get is fluid leaking out around the manual release button. Is there a kit I can purchase to rebuild the valve body?
