Tilt trim pump.
brian3127
What fluid do I use to fill it back up.
I moved it to paint the deck and it tipped over. Though the night and leaked
dubs283
The fluid was red. Is that tranny fluid or something else different.
Most likely ATF, Dexron 3. Is okay to use however mercury uses 10w30 motor oil in all new trim systems from the factory and recommends using 10w30 or their branded power steering/trim tilt fluid
