Frank Acampora
- Jan 19, 2007
- 12,004
OK, RRitt. I need your help. What is wrong with these two pumps? They will raise the engine but not lower it. Do they require a second check ball and spring at the rear (down) side of the pump? Also, the front of the check valve keeps popping out. Can I stake it to keep it in or is there a good glue? Is This the source of the problem?
Everything else works fine. Motor turns in both directions and cylinders are moving freely since I can lower the engine if I remove the front check valve and let them bleed down
