Tilt Trim Question
dgopetactical
88 MERC 5.7 ALPHA 1
I bought this boat in early spring. When pushing the tilt button up to raise the unit it would work then stop. I had to put the boat in neutral and use the trailer button to raise the unit. the down side worked great.
the last time I was out the down side started doing the same thing. If you push the button a few times it works. when it doesnt work you hear a clicking when you push the button. any ideas?
thank you in advance,
Dennis
Re: Tilt Trim Question
The Wiring is probably the Issue.........
On the Up-side,.... I'm guessing that you're running it up to the Trim Limit,...... Then you have to use the Trailer Button....
That's the way it's Supposed to Work.........
On the Down-side,...... It sounds like Dirty, or Failing Wiring..........
Don S
Here is a link to the Merc Service manual.
Click here then scroll to the last page (outline) click on the word Troubleshooting under section 1C. The wiring diagrams and troubleshooting charts should help you understand and locate the problem a lot easier.
