thienpham817
- May 19, 2004
- 11
I just bought a used 17' 1999 I/O . The boat runs good but only one problem : anytime after i took it out for a ride , i noticed that oil is leaked around the trim and tilt 's reservoir tank . Can anyone tell me what cause it? My tilt system is working great. There is a litle hole on top of the reservoir cap ,i think it suppose to be there.Maybe the oil leaking from that hole or the gap between the reservoir and the pump motor(?) that sit on top of it ( i look and it seems there isn't a gasket or anything there ). I'm pretty sure i'm using the right fluid for tilt and trimming system. Please help on fixing that leak. Thank you in advance. Tim.
