Tilt/Trim Slow going down
ddclapp
Hello, I am having an issue with my tilt/trim on a 1984 Mercruiser 260. The issue is it works great in the up direction - fast and smooth. But going in the down direction it is very slow. It will eventually make it but seems to take forever. I am assuming this might be an issue with a valve, but is it repairable or replaceable.
Also I examined my trim motor/pump and examined where the lines are going in and out. How do you check this for oil level/contamination. It looks like you only can check the top to see if the level is ok, but how do you check for water in system?
thanks!
stonyloam
Re: Tilt/Trim Slow going down
You need to go up to the "adults only" section above. #9, download manual #6 alpha 1 manual, and look at section 5A Trim pump. They have a section on testing and repairing the trim pump. Good luck.
ddclapp
Thank you for your quick response - I did some research and found a link to
the actual trim pump/motor that I have - an oildyne Power trim pump with a metal reservoir. Here is the link if any one had an mid 1980s 260 mercruiser and wants to identify their system (squarish motor and round metal cylinder for fluid/pump:
http://www.boatfix.com/merc/Servmanl/6/6B5R3.PDF
Next I think I need to replace the down pressure relief valve, and probably the filters in the part. So my next question:
I can find references to a Trim Rebuild Kit - but no list of the actual parts for this kit. What is in the kit? -Mercruiser part #99073A2. I can buy some of the parts individually, that I think I need but is the kit what I need?
Anyone familiar with this REBUILD KIT-TRIM? Any other rebuild suggestions?
Thanks!
