Tilt/Trim stuck/leak/bearing fell out
corydat
I have a Evinrude 89' 40. I was working on the tilt trim today trying to fill the reservoir after it had leaked some fluid out of the top of the cylinder. I filled it up cycled it 4-5 times. Everything was working ok. Then I walked away and let it sit about 3/4 up and now the trim is stuck. The trim motor turns but no movement. So I remove the drain plug at the bottom hopeing that would allow the fluid to drain and engine come down. When I remove the drain screw a small bearing fell out and the tilt didn't budge.
So the leaking was already a problem but now the problem is that it's stuck, and the bearing falling out. What do I do about this bearing? And it being stuck?
Thanks a lot.
Cory
