I have 1999 Johnson 150 hp. My trim/tilt sytem was kind of hesitant to go up after a fishing trip last week. After inspecting the unit I notice that one of the outer seals on my trim rod cap came completely off draining most of the fluid in the system. After removing the cap and replacing the seal I drained all the existing fluid in the system and replaced with ATF Dexron 3. Put the caps back on and lift the motor up to full tilt position and added fluid to the reservoir. Next I maually let the motor down and lifted back up to add more fluid. A little fluid was coming out so I let it down a little to add more fluid but it didn't really take much fluid. Let the motor down again manually then lifted back up. When I took the fill cap off the fluid starts to come out. Can someone please help me out with this and let me know what I am doing wrong because I can't get the motor to raise up when I hit the switch. Nor will it take anymore fluid. By the way the motor sounds fine!
THanks
THanks
