tilt trim toggle and water muffs
sea king guy
Good Morning,, solittle, thanks for the info, I hooked up the muffs, turned on the water and I did get the motor started, now I am really new to this, but the only water coming back out, came thru a little rubber tube at the bottom of the motor, ...a steady stream..... also when using the muffs, should all the water be sucked into the lower unit? seems like i still have alot of spraying out where the muffs attach,,.. even tho they appear to be in pretty secure. Also any ideas of a inernet site to pickup the toggle switch for the tilt and trim? I have the rest of the parts.
D
DJ
Guest
Re: tilt trim toggle and water muffs
mcj,<br /><br />The water exiting the engine at the bottom of the cowl is called the "telltale. That is a good thing.
