tilt/trim units
DKHunter1
I have a merc cruiser Alpha one. The trim on the throttle to go up only works when the boat is out of the water. When in the water I have to use the trailer trim to raise the leg. I am guessing it is shorting out when in the water. not sure where it would be shorting from as the wires look in good shape
Chris1956
The trim limit switch on those Alpha units in on one of the pivot points of the outdrive that is submerged. It is under a plastic cover. Likely the switch guts have gone bad.
The other pivot point is the trim gauge sender. It is a copper pointer and coil that moves as the drive trims up/down.
