tilt/trim walkthrough for a noob
angel_guardian
I've rebuilt a 135 merc blackmax that came with the tilt trim setup built into transom bar, unfortunately I'm lost when it comes to what I'm missing. There are two hydraulic lines coming up from below the motor where the tilt bar and what looks like a motor are. The lines are metal with a cupped end facing the front of the boat. I am not sure which is the resorvoir or the motor and which part it is that I need to complete the setup.. When I manually lift the motor fluid (hydraulic I assume) shoots out of these lines. ANY help would be greatly appreciated. Thanks in Advance, Sean.
Chris1956
Re: tilt/trim walkthrough for a noob
The year of the motor (V6 or IL6) and a picture would help. Early OEM PTT units had 4 hydraulic lines. Later OEM Units had none.
is your PTT unit OEM or some aftermarket kit?
angel_guardian
its an 86 or 87 v6; i don't have a pic right off hand but will try to get one of a similar setup that i have.
angel_guardian
here is a pic of the setup i have mine is just actually attached to the boat.
Chris1956
That PTT unit doesn't have any hydraulic lines. It has a power cable to the PTT motor, but that is all. I guess a picture of your actual motor would be inorder.
