tilt / trim - wiring ? blue / green / black
casi77
I have this tilt trim for johnson, 3 wrire.
How do we wire this up ?
Believe you require 2 starter solenoids instead of regular 12 volt relays because this one draws too much current not like the 2 wire setup?
wires from the tilt/trim: black (ground), blue(believe this is UP), green (down)
anybody have a wiring diagram to hook this up with 2 starter solenoids ?
(solenoid have the S, I, power from battery, to device)
thanks
D
DJ
Guest
Re: tilt / trim - wiring ? blue / green / black
Black = Common
Blue = Up
Green = Down
What year and HP is the engine? Give a model number, if you have it.
casi77
model: 50ESL73R 50hp 1973
with power tilt unit
DWJ said:
Black = Common
Blue = Up
Green = Down
