can you switch out a 2 wire for a 3 wire hydraulic tilt on a 1998 90 hp force outboard
B bjim Recruit Joined Aug 3, 2012 Messages 1 Aug 3, 2012 #1 can you switch out a 2 wire for a 3 wire hydraulic tilt on a 1998 90 hp force outboard
F foodfisher Captain Joined Feb 18, 2009 Messages 3,756 Aug 3, 2012 #2 Re: tilt I believe so, but you'll have to wait for the how to's. Edit: I'm the last person to ask for elec info.
jerryjerry05 Supreme Mariner Joined May 7, 2008 Messages 18,183 Aug 4, 2012 #3 Re: tilt If it just an electric motor swap it's possible.Need to show parts and pieces. The older models were easy to change.
R RRitt Captain Joined Mar 30, 2006 Messages 3,319 Aug 8, 2012 #4 Re: tilt the oil tubes are bent to match the electric motor. otherwise systems are interchangeable.
