itsaboattime
- Jul 4, 2007
- 791
My set-up is like this, I have a 1987 Evinrude 110 horse, model E110tlcur. My boat is a 1983 4winns Marquise 160 F & S. The prop that came with the motor, I got it used about 2 months ago, is 13 3/8 X 17.
My boat is rated for 120 horses. My top speed with this outboard is right around 45 mph. My hole shot couldn't be better.
I have no real complaints with this prop. I do have a concern tho. The max RPM for this motor is 5000 to 5500. I can and have (accidently) had it to6000 rpm. I ended up popping a power pack.
My question is, do I get another, higher pitch, prop to slow down my WOT?
I looked up my motor here on iboats and found a wide range of props that will work for it. I am considering picking up a Turning Point Hustler #H2-1319 Aluminum three blade Propeller. It is 13 1/4 X 19.
All of the 17p props offered are a smaller diameter and I don't think they will help me with my over-revving. There is only one 18p prop offered and it's stainless, way over my price range right now.
I know that the simple solution to over revving is to keep my hand outta the throttle, but, I am not the only one to drive the boat. My daughter is learning to drive it and I really don't want to replace another power-pack. I am not worried about my speed and if I pick up a little more then ok. If I lose a little then ok too.
I may lose a little on the hole shot with this prop but that isn't a concern. I just want to bring the WOT down.
