Timer base resistance readings
Arty76
I have a 1995 Johnson 200hp. Venom. I've been checking the resistance on the connectors of my timer base following the instructions in my Seloc repair manuals (I have two of them), the best I can get is about 740 ohms from the white to the colored pins, from port side white to starboard side white/ black is about 230. I think the 230 is ok, but the 740 readings are too low, which indicates the timer base is bad, correct??
