Timer base test results
Chevyls6
Hey guys I've continued to test my ignition chasing a wot running issue.
My results may indicate a failing trigger coil but I wanna run it by someone knowledgeable since it's a super expensive part.
Ok so according to cdi the coil should read 10-20 ohms resistance and a trigger signal of .6v+
My coils read 8 ohms per and between 1.5 and 2v for the trigger signal.
Is this normal ?
1977 v4 Evinrude
