Timing 1977 85 hp v4 evinrude after rebuild
HBF4
I finally got my engine together after a long rebuild project, and now I want to start it. I have 2 manuals, but both call out a tool for timing at TDC that I dont own. Any recommendations on timing the engine. Also, how should I mix the fuel to break it in? I honed the cylinders, put on new rings. Any suggestions would be welcomed. It's finally getting warm enought here where I want to go out boating.
Solittle
Re: Timing 1977 85 hp v4 evinrude after rebuild
Joe Reeves has a post on timing your motor with the boat on the trailer & engine off. Use the search to find it.<br /><br />Your motor calls for 50:1 gas to oil. For the first 10 hours double the oil to 25:1. I would run the motor at 1500 rpm or less for the first hour. Hour 2-5 get it up on plane but keep the rpm down varying it frequently. Hour 6-10 do the same but raise the peak rpm gradually with occasional bursts to WOT. Key thing is to keep varying the rpm.<br /><br />Check the torque on the head bolts at 10 hrs & go to the 50:1 mix.
Dhadley
The tool you mention is for setting the timing pointer which is critical. Once thats set you can proceed with setting the actual timing.<br /><br />The most important, and most overlooked, thing about any rebuild is to correct the cause of the original failure. A broken ring or a damaged piston is not a cause. Thats an effect.
