I know this is probably way up the garden path. I checked the timing whilst the engine was running at 1500 rpm idel speed. #1 cylinder and the timing was 180 degrees out. Is this because there was no load on it? Or is it really 180 degrees out. I wouldn't have thought the motor would run with this set up? If so could you point me in the right direction of how to alter the timing???
Thanks
Peter
Thanks
Peter
