Timing 1984 115 i6
MortenH
Hello all<br /><br />I have done the same trick as Lion hunter - removed the flyweel by using the small nuts on the top. Lion hunter got the tip to use the one mark on the side of the flyweel to allign with the pointer. My flyweel have several marks on the side. There is one marked with a 0 (zero). Is this the one I shall align to the pointer?<br /><br />-M-
Chris1956
Re: Timing 1984 115 i6
Norway, Turn the inner flywheel until a screwdriver indicates the top piston is set to top dead center. Now install the outer flywheel so the pointer reads top dead center and put in the six bolts.
MortenH
Thanks Chris!<br />I will try this as soon as I have assembled the rest fo the engine.<br /><br />-M-
Clams Canino
How will you change the seal in the upper endcap?<br /><br />-W
MortenH
I have had the "inner" small flyweel hub removed by my local merc dealer (he had a flyweel puller), so there will be no problem in replacing this.<br />Thanks<br /><br />-M-
