Having now almost finished building up a replacement powerhead (1997 70 full remote), I need to sort out the timing.
This http://forums.iboats.com/showthread.php?t=228183 from the secret files is excellent and pretty much is what I had considered doing. My engine calls for 18 BTDC at WOT and 4 BTDC (3 - 5) at idle, so using this method I would set to 14 BTDC. The only difference is that I will use No1 plug in the engine which will be empty of fuel and the bores / bottom end will be lubed with fogging oil.
However, I am sure my engine has QuickStart (CD3 system) which advances the timing automatically when cold ........... how do I disable this feature ?
Or, if it cant be disabled, how much advance does it provide (I can then allow for it in the above calculations) ?
Thanks ............
Thanks ............
