Timing 3.0L
I have a 1990 merc I/0 3.0L with the digital ignition. There are two wires coming off the distributor (Red & White) going to the module. The question is how do I set/ check the base timing?
Mike
Rocky_Road
Re: Timing 3.0L
Does this look like your setup?
Re: Timing 3.0L
Thanks Don, I think that did the trick, When I checked it after I warmed it up it was at about 16* btdc I set it to 8* and adjusted the carb and it seems much better, I will find out tomorrow when I take it out.
Thanks again
Mike
Re: Timing 3.0L
Well it was a little better, but it sure wasn't perfect. also it back fired a few times while trying to pull a skier out of the water. any ideas?
Re: Timing 3.0L
Ayuh,... That's usually a sign of a Lean condition....
Check,+ Change the Fuel Filters...
