Timing a 88 50hp force
Rickerd
Should I time my 1988 50hp Force With or Without plugs Installed?
Serial # 507Y8C
jerryjerry05
Re: Timing a 88 50hp force
Out.Static timing needs to be done while the plug leads are grounded.
Got a manyal? Get the factory one.J
Rickerd
I have a Clymer Manual, Directions start as to remove the plugs and check for TDC. Then it gos on to say check timing with WOT and crank engine. doesn't say anything about reinstalling plugs. That leads me to believe that the plugs should stay out, but its not totally clear.. Serial # 507Y8C
