I have the EST ignition where all of the timing advance is done in the module. The engine is way too advanced at idle (about 20°) which makes it hard to start and diesels after key shut off. Shift interupter switch is set right and works as designed. Timing is set as outlined in manual (jumper wire on two leads at distributor and shift interupter switch wires connected together). I suspect the manual is wrong about shift interupter switch wires together (this would be the same as switch closed-hey it's a Clymer manual). So do I have bad advice from Clymer or do I have a bad module? Thanks in advance, no pun intended.
