Re: Timing adjustment on 92 70 hp Force
Tying off at a dock and going to WOT is not a very safe. If a cleat were to let go, or the rope break, who knows what will happen. Even cruising out on the lake and going WOT to check timing is not safe either. You may hit a wake/wave and get thrown into the spinning flywheel.
For static checking, the reason they say to use a spark tester, is to prevent damage to the switch box or CD units. You have to discharge the spark that is being generated. Just disconnecting the plug wires and leaving them dangling while cranking the motor may cause damage. You have to either hook up a spark checker, or ground the spark plug wires. They say to remove the prop probably to prevent accidental injury from the spinning prop. I just make sure I'm not close to the prop, or keep anyone around away.
