RaceCarRich
- May 31, 2015
- 234
New guy here says hello. Just got my first boat and am learning all I can. Was giving my used boat a once over and tune-up before taking to water. Noticed the following:
Timing in Base Mode: 2 ATDC like posted on flame arrestor = COOL
At Idle (out of Base Mode): 11-12 BTDC = COOL
Full Advance (out of Base Mode): 20 BTDC @ as high as 2800. = NOT COOL???
Everything I have read says it should be 27 BTDC all in. Also, most of what I have read would indicate it is common for base spec to be 1 ATDC unlike what the stock (I know the original owner & he didn't change it) flame arrestor specs of mine.
Do you think the issue is in the module? Is this a common failure mode? Does my engine have a slightly difference advance curve from the more common ones I've read about and, if so, what is the full advance spec? How concerned should I be?
Thanks in advance
Thanks in advance
