i just switched over to electronic ignition and set the timing. the specs call for 6 degree btdc but i found the engine didn't idle smooth at that and seemed to like 10 degree advance better. any harm in leaving it at 10? will this cause detonation? i had her out yesterday and she didn't seem right, she seemed to be straining at higher rpm's and i had trouble with her stalling when putting into gear. i think this might be a carb problem and unrelated as the stalling when putting into gear was also happening last year. any thoughts? the engine is a inline 6 165hp
