Timing and sync. help please.
Searcher 200
I have been going Through my manual and searching the forum for hours now and I can't find a ref. to which plug is #1 on my '78 115hp. I thought it was upper left but a pic in the manual shows right bank upper. Also when I was synchronizing the carbs, my lower throttle screw was frozen. I should have checked the manual before doing it but I released the upper screw to let the throttle plates close. Is there a problem? All the points line up and plates in both carbs open at one time. Any help is appreciated.
ezeke
Re: Timing and sync. help please.
They are numbered from top to bottom the way they connect to the crank.
Facing from the rear: number 1 is top right; top left is 2; bottom right is 3; bottom left is 4.
