Timing chain
mr. b
Is there a difference between a marine timing chain or car timing chain on reverse rotation motor? If I were going to rebuild a reverse rotation motor could I just change the cam, starter and distributor or does it involve more?
Re: Timing chain
Well,..... You don't give enough Info to properly Answer your Question........
If, by chance we're talking about a Chevy based motor,.....
The Timing Chain,+ Sprockets are Swapped for Timing Gears......
That allows the Crankshaft to turn CW, while the Cam,+ Dist. continue to rotate in the Same direction they always Do.......
