Re: Timing curve for the 5.7L ecm conversion 807264A01
Yes, I do have that module. It seems high, but reset the base to 10 degrees, and idle to spec (650rpm), and check what you get for advance in base mode. Make sure you have a good ground when putting in base mode. Retest in normal mode, and see what voltage is at the pur/wht connector.
Was it pinging, or making some noise that led you to check the advance? or just installed it and testing?
