I am putting together a 153 cu in Merc 120 engine. I did not mark the camshaft gear when I took it apart, assuming that there would be a mark on the camshaft, and there is not. Need help with positioning camshaft gear to crankshaft gear. I don't have a problem with TDC. I think that if I line up the thrust bolt holes, the mark should be directly across .....
