So I have a Mercruiser 470 and I've go it where it will run, but only when I have some throttle on it. I have looked at it with a timing light and the timing is out. It is supposed to be 8 Deg. BTDC and when I tested it, the lines on the block and fly wheel were way off. So anyways I start to slightly turn the distributor to line them up, and the closer it gets to being lined up, the more the motor bogs down, eventually shutting off before I can get them lined up. Any suggestions?
