Is there a special type of timing light to use on a 2 cylinder boat engine or can you use the same one's that you use on a car? I just got a 30HP 1989 Johnson Electric start that was missing the the ignition timing screw. I got a replacement screw and nut but have no idea how far in to turn it initially. Any advise on how to approach this timing issue would be appreciated.<br />Thanks!
