Re: Timing on 120 hp
Its a 1992 120 hp l drive in a maxum 2100 ldc. I have changed stator, rebuilt fuel pump, and changed fuel hoses. A mechanic here in town said to check timing at cranking speed at WOT. Iy was pretty far off so i adjusted it back to 30* per Clymer manual. Compression was okay at 110,115,115,120. Spark ok too. Im going to go to the water today to test run. I will post later with results.
