Timing Outboard force
Seb01190
Hello
I am French and I do not have a strobe light
Will you give me the distance between the two black pieces, to have a setting at 32 °
for info my engine is a force of 1990 Thank you in advanced
Isa4325
Feel under that gear to see if there is a mark under your TDC to verify it is TDC.
Redbarron%%
The distance between the two black linkages is not a good way to time the engine. Borrow a timing light to set the timing.
Here in the US auto parts stores will often loan tools like this.Perhaps there is a similar service offered in France.
You should verify TDC with # 1 piston at the top of travel by pulling the plug and using a screwdriver to feel the piston movement.
Then you can count the number of teeth on the flywheel and divide that into 360 to get the number of degrees per tooth to measure the places to mark the timing points.
Be sure to verify the TDC as sometimes a backfire will shear the key that attaches the flywheel to the crankshaft.
I am working on a motor currently that had this exact problem causing the whole boat to be abandoned as not worth fixing.
Seb01190
Ok thank you for the responses; i will check the TDC to night. For information, my flywheel have three marks; 28-30-and 32°. Not 36°.
Seb01190
Hello all
It's finish for this problem , i have setting the timing with the strobe
Thank you
