Just had my 3.0 rebuilt. Got the engine back in the boat and the outdrive back on. Put the boat in the water and it started right up, with a little tweaking of the distributor cap, and ran fine as far as a fella could tell. I figured I should check the timing so got a timing light (I had marked the correct timing on the tab with chalk) but the "notch" on the pulley was never close to the tab. My mercruiser manual does not indicate that I need to jump any wires, but I find some timing procedures that reference jumping wires in the distributor and jumping the shift interrupter switch.
Do I need to make "jumps" to time my engine?
Should I set dwell, point gap, or adjust carb prior to timing?
Basically looking for the tune up procedure for an engine that has just been rebuilt.
Appreciate any help I can get.
